I have an animated intro clip that I want to look like an old monster movie. I've already desaturated it, but I think it needs some noise added. Was hoping someone out there had a Virtualdub plugin for this, but I can't locate one. Suggestions?
Answered my own question, eventually:
http://compression.graphicon.ru/video/old_cinema/index_en.html -
Digieffects Cinemotion plugin for AfterEffects does a great job, but is probably more expensive than you want.
the cheapest way I know would be to find a copy of ParticleIllusion and then do a google search for Elvis Deane's webpage, he has a set of emitters and some scripts to add noise, dust, scratches, etc.
If you can find it, the August issue of Digit Magazine had a full version of pIllusion 2.0 on the cover disc.
but if you can find a Virtualdub filter or another freeware method, make sure you post it and share with the class...
**edit** - you beat me to the punch, while I was writing the reply! good find - that plugin looks great...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
virtualdub filters - these will work just as good as any commercial version:
http://compression.graphicon.ru/video/noise_generation/index_en.html
add (just a few) stains first, then use:
and your all set .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I just tried it out, and it works very well. I'm quite happy.Originally Posted by housepig
DVD authoring program that will add Macrovision
By Nolonemo in forum Authoring (VCD/SVCD)Replies: 19Last Post: 31st Oct 2010, 03:26 -
Program to add a menu to a DVD...
By Soccerman77 in forum Authoring (DVD)Replies: 1Last Post: 14th Sep 2008, 03:45 -
Want to add noise reduction to whole CD, not just each track in Audacity
By happydog500 in forum AudioReplies: 8Last Post: 25th Mar 2008, 01:05 -
Best program to add clips together?
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 02:47 -
Need a program that can edit movies and add music
By LITEONDVD in forum Newbie / General discussionsReplies: 2Last Post: 28th Sep 2007, 16:20
