  1. I thought I had my conversion down but I guess I don't. After I convert my "DV"avi file with TMPGEnc and then use ULread Workshop to author I get jerky video like when the Camera pans and the thing is when I view it on the computer it looks ok but when I burn and play on TV thats when I see the video being jerky. So I'm guessing It's something in TMPGEnc causing this. I read all the guides but I'm quessing I have a setting in TMPGEnc that is off that is causing this. Any suggestions would be appreciated.
    Thank's
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    This sounds field order related. Try selecting the opposite of what you are using now. Unfortunately re-encoding and authoring a new disc is required to verify whether this issue is in fact your problem. Use RW media if you have 'em.
  3. It's your frame order. Use the wizard in TMPGEnc and it will figure out the correct field order for you.
  4. That was the problem Thank's so much for the help.
