Hi,
I've just started making DVD-R recordings on my Panasonic DMR-E100. It sounds fine on my Panasonic DMR-E100. However when I play it back on my Playstation 2 the sound is tinny, like the actors are speaking through a sheet of tin foil.
I recorded the shows from Sky Digital using thor scart cables. I recorded the shows to the hard drive at XP quality and transferred at high speed to Panasonic DVD-R discs. I recorded the shows using the Panasonic Dolby Digital sound settings.
Does anyone here know whats wrong?
Any help would be greatly appreciated.
You might have the setting wrong on the PS2 I seen this with my Pioneer DVD player. I had to play with the audio setting for a sec to fix it.
Hey Jedi55,
I get similar problem - I make a DVD-R on my E100H, then when I play on my stand alone DVD player it defaults to the DolbyDigital2.0 soundtrack and it sounds very loud and slightly distorted. If I select the non-dolby digital soundtrack the volume levels are OK. So it seems that that 2.0 soundtrack may record with too high levels?
Do you know which soundtrack your PS2 is picking up?
Cheers. -
This doesn't make any sense. The Panny DMR-E100 only records a single audio track at a time.Originally Posted by Wobble Pants
Panasonic DMR BW880 & Windows Media Player - no Sound
By cubenz in forum Media Center PC / MediaCentersReplies: 0Last Post: 9th May 2011, 05:34 -
Panasonic DMR-EA18 recording help needed. No sound in video playback.
By LegendaryGamer in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2010, 09:52 -
Panasonic DMR-E100 or E100H unlock codes to make region free
By Johnmunch in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Apr 2010, 16:58 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45
