Hi!
I have a little confusion in my mind..
Well my original file is an AVI I'd like to author it on a DVD so that i can view them on a stand alone player..
I have tried to do that in several way following different guide but doesn't work..
I have tried to use TMGgenc Author, NeoDVD but nothing they don't work..
I don't understand well the right step to conversion->author can you pls check if i have understood right:
From the AVI file I convert to MPG with audio 48000 K with TMPgenc Plus.
With for example TMPgenc Author i create the file VOB and IFO and automatically burn it.
If try to get only IFO and VOB how can i burn that with Nero?
How can i put more than one video?
Thanks in advance regards
haltman
yes. you can convert several avis with tmpgenc and then add all in tmpgenc dvd author.Originally Posted by The haltman
Software confusion..............
By wickedbartender in forum Software PlayingReplies: 1Last Post: 12th Mar 2010, 04:18 -
Bluray confusion
By Border Reiver in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2009, 17:41 -
AVIVO Confusion
By jameson_uk in forum Software PlayingReplies: 2Last Post: 11th Sep 2008, 18:44 -
Video CD confusion
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 6th Jan 2008, 18:17 -
16:9 to 4:3 confusion
By zabolots in forum Video ConversionReplies: 5Last Post: 17th Jul 2007, 15:32
