I have problem converting what I think is Xvid file to mpeg.
I have a clip naming xvid. avi. but when I right click and check the properties, it says .avi file. So is it Xvid file? or avi? or xvid and avi together if there's such a thing.
Anyway, I put this clip in tmpgenc souce creator and also tmpgenc plus (basically the same thing) it says unsupported, so I think it is definately not avi file (because you can convert avi to mpeg using tmpgenc)
So my question is what program(s) are good for converting this xvid (I think) to mpeg?
Oh, by the way, converting avi to mpeg using tmpgenc takes quite a long time. Wondering what other programs to convert avi to mpeg with shorter time and quality is as good as the original? Freeware or shareware is good too:P
thanks in advance guys.
meocat9
avi is just a container format, it can be divx, xvid, dv, mjpeg... video. Use gspot to identify what video codecs that is used in your avi.
Installed a xvid codec?
Tried change the directshow reader in tmpgenc?
www.dvdrhelp.com/tmpgenc#problems
other faster mpeg encoders: mainconcept mpeg encoder, cinemacraft encoder basic, canopus procoder express. -
Thanks for the help. Sorry about the other post, I had problem posting when I did, I got an error message so I thought I tried the other forum section but got both message posted afterwards.... So sorry about that and thanks for the tip.
So tmpgenc can actually convert from xvid to mpeg? I just have to change the directshow reader? Good/bad or any affect on quality when changing this option?
Thanks again. -
You definitely need the xvid codec and you may need to raise the directshow priority. Read and follow Baldrick's advice.Originally Posted by meocat9"Art is making something out of nothing and selling it." - Frank Zappa
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 21:00 -
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 13th Dec 2009, 00:44 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 21:51 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 16:04 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 16:10
