  1. I am close to the end of my tether with this. I am simply trying to capture my home movies to VCD in the best quality possible. I invested in a WinTV PVR PCI card thinking this would be the solution. Wrong. I've tried using the WinTV standard VCD recorder but the quality is very poor.
    So I've tried the VirtualDub/Huffyuv method with limited success. Heres my list of problems. Can anyone shed any light on these please?
    - I select s-video on WinTV then exit. When I connect to s-video in VirtualDub the pic is in B&W.
    - The sound I hear is from the TV card line in, but the avi records from the microphone!
    - If I have DMA selected for my HDD, I get visual interference every time the HDD fires up
    - If I dont have DMA I get a slide show.
    Arrgghh!!
  2. ....I ought to add I have a PIII 800 with 256 RAM, 27GB HDD and a Chaintech motherboard with VIA chipset. All latest drivers installed.
    Jun 2001
    England
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>- I select s-video on WinTV then exit. When I connect to s-video in VirtualDub the pic is in B&W. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Your home movie source is probably outputting composite video (through an S-Video lead) You either need to adjust your source to output S-Video or use the composite input on your capture card.
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>- The sound I hear is from the TV card line in, but the avi records from the microphone! </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Double click the speaker item in the taskbar (next to the clock) Select recording levels from the menu and move the checkbox from Mic to Line-in
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>- If I have DMA selected for my HDD, I get visual interference every time the HDD fires up </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Ensure you are using a good quality shielded lead from your movie source to the capture card. If the lead is OK then it sounds like a problem with an electrical earth/ground somewhere.
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>- If I dont have DMA I get a slide show. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Correct.
    Don't lose faith... you're almost there! Carry on down the HUFFYUV or MJPEG route, they will give you far better results then using the WinTV recorder.
    <font size=-1>[ This Message was edited by: Dave B on 2001-10-26 06:23:56 ]</font>
  4. Dave, thanks for your reply.
    - When I view my s-video on WinTv it is in colour. It switches to B&W when I fire up VirtualDub.
    - I dont have a 'recording levels' menu option! I'm running Win98SE and I have SB Live! 1024.
    - I have an interference problem when I playback my MP3s with WinAmp too, so I'll have to check my earths. Maybe a call to my PC manufacturer is in order. I still dont understand why it doesnt happen in non-DMA mode though....
    Jun 2001
    England
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>- When I view my s-video on WinTv it is in colour. It switches to B&W when I fire up VirtualDub. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Err... right. It sounds like you've got a NTSC/PAL problem when capturing. Try finding a way to change the "Input Standard" in the Virtualdub/Capture Card settings menu.
    If all else fails, download AVI_IO (in my opinion, a better capturing program) and see if that has the same problem.
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>- I dont have a 'recording levels' menu option! I'm running Win98SE and I have SB Live! 1024. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Volume Recorder Panel -> Options -> Properties -> Adjust Volume for -> Recording -> OK -> Check Line-in box
    Lovely.
  6. I have solved all my problems! FWIW and FYI heres what I had to do:
    1) The WinTV drivers were the problem with the B&W picture. I had a WinTV PVR card installed. I removed this and replaced it with my old WinTV PCI card. I installed drivers version 4.18 and it works. (I had exactly the same problem using 4.2 drivers with the old card too).
    2) Run WinTV AUDIOSEL.exe to select line-in. Doh!
    3) The interference was caused by the DMA drivers on my motherboards VIA chipset. I downloaded the latest 4-in-1 drivers and an IDETool from the VIA web page. With the IDE tool I was able to select one of 10 different DMA modes. One of them cured the interference problem completely!
