after installation ffdshow my computer is crashing by playing with windows player 9...
if i remove ffdshow everything is ok....but i need ffdshow for some avi to play...even if xvid is installed movie is not playing good as when ffdshow is installed...
where can be a problem?
can i have all codecs divx 3,4,5 and xvid a ffdshow installed to play evrything ok with windows media player 9....
thanks for help...
tried the latest version?
you could also try some older versions and see if it works better.
http://www.ligh.de/software/mirrors.phtml -
Installed ffdshow and now my computer is really slow
By AaBbCc in forum ComputerReplies: 3Last Post: 3rd Jan 2012, 09:11 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 05:42 -
Audio codec problems after installing K-Lite and ffdshow
By iggie in forum AudioReplies: 6Last Post: 17th Dec 2008, 06:39 -
VobSub crashing computer?
By IronmonkY in forum SubtitleReplies: 0Last Post: 28th Dec 2007, 22:14 -
Help! Computer crashing every 15mins
By DuBsTaR in forum ComputerReplies: 21Last Post: 24th Sep 2007, 18:42
