hello
i am receiving this problem:
The following codecs all claim to be capable of processing this format
--> {XviD MPEG-4 Codec}
--> {XviD MPEG-4 Video Decoder}
{Sigma REALmagic MPEG-4 Video Decoder}(misconfigured! click on it for info)
as you can see sigma real mpeg4 codec je misconfigured probably i removed it wrong from computer...
is there any good program to fix this a remove all codecs we do not need or remove all misconfigured codecs?
thanks much...
please do not double post - one topic is enough
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
How to remove the remove redundant tracks of *.ts?
By UMO in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:30 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
how to remove everything off my HD?
By mvp in forum ComputerReplies: 9Last Post: 12th May 2008, 13:40
