Why do some progs ask that you reboot after an uninstall and some don't? I have always noticed this but have never really understood why this must be done...Just now I uninstalled a prog and it asked if I want to reboot now or later. What does the comp do once I reboot?
Boy do I love my avatar!
some programs modify/add things to the registry. the only way for windows to recognize these changes is to reboot, and let windows re-load the registry. so if a prog doesnt ask you to restart, then it didnt change the registry
Another reason is that some programs load at startup and remain in memory. While not the only way, the easiest was to remove the startup command (registry as mentioned) and reboot. Often, if programs are in use Windows won't let you delete them. The sequence becomes 1. get them out of use, 2. delete them.
Computer keeps rebooting again
By Illusionist in forum ComputerReplies: 5Last Post: 11th Apr 2011, 18:19 -
xp keeps rebooting
By Illusionist in forum ComputerReplies: 1Last Post: 8th Apr 2011, 12:43 -
TMT3 is Rebooting My Computer
By wulf109 in forum ComputerReplies: 6Last Post: 21st Oct 2010, 12:09 -
about rebooting pc
By ieh4f in forum ComputerReplies: 8Last Post: 31st Aug 2007, 18:07 -
Box keeps rebooting after...
By makntraks in forum ComputerReplies: 8Last Post: 24th Jul 2007, 22:10
