Ok, I'm trying to make a DVD with a bunch of mpeg1 files on it and I am having sync problems with multiple mpegs.
First I just did a couple m1v files and their corresponding mp2 sound files to see if my set-top will play the 44.1KHZ audio ... no sync or other problems there.
Next I add ~4.0gb of mpeg1 video that is demuxed already and I build a disc image.
The resulting image is only ~2.5gb and the video/audio is majorly out of sync once I get past the first few chapters.
Any suggestions.
Something is up with the demuxed mpeg files.
I just tried building an image with Sizzle 0.1 with one m1v/mp2 chapter and the result should be a 450mb image but it's only 12mb.
I then used the same demuxed files in Sizzle 0.5b1 with a simple black menu and one title set and it made an image the proper size 450mb and it plays in DVD player (but the text on the buttons don't work 'cause of the bug).
I also tried MPEG2 Works 3.4.2 and Gumby to remux the same files but they screw up and make a 7mb mpeg file.
I used MPEG2 Works initially to demux the original mpeg file.
Confusing no?
Sizzle help
By danielmak in forum MacReplies: 3Last Post: 3rd Mar 2010, 07:37 -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 14:14 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 13:45
