I need some help on this one
I dont loaded a file is this format
.xl.3ivx
and it also says MOV under it,
nothing will decode it to DVD
what is it???? and what program do I use
Tom
You have a movie with 3ivx video. It can be played with Quicktime or in your standard media player if you install the 3ivx decoder. Converting it to DVD is a little tricky. See this thread: https://www.videohelp.com/forum/viewtopic.php?t=212334
If your finished mpeg doesn't have sound, see this thread too: https://www.videohelp.com/forum/viewtopic.php?t=212440
As you will see, this isn't a particularly easy conversion to attempt. If you are feeling bold, give it a go. -
Well, first understand that the NAME of a file has absolutely nothing to do with the format. This particular extension SUGGESTS that the file is Divx version 3.
The MOV, (underneath WHAT exactly? You are aware that I cannot see your screen from here?) would indicate it might be an MOV file.
Try opening with VDUB, WMP, TMPGENC, and/or a Divx player. Once you open it, check file info or properties to determine what the file actually is. Then follow the appropriate guide.
