Anyone have any Ideas as to why this recorder records everything to DARK? I have tried from every source imagineable but all to no avail, even if I record direct from the tv. It is still darker then normal, what good does this recorder do me if I can't even record a program or sports event where the picture is darker then normal. I mean it really shows up when there is a nite scene. Any help anyone can give would be greatly appreciated. I have looked into the clarifier but, it says nothing about picture darkness or birghtness, just about macrovision protection, thats fine if I am going to make a backup of an exsisting vhs movie I have, but makes no sense when tv picture straight from my direct tv is dark then normal, no macrovision present in that, so I don't see where it will help.
It could just be faulty!Originally Posted by sejac
Have you tried exchanging it for another unit at the store you bought it from?
Nezza -
Have you tried to set the black level under the system menu options? One setting results in a darker looking picture.
I think the setting are either on or off.
Good Luck...
The OldeMan
SOLVED: Media Player Classic - playback picture too dark......
By bahjan in forum Software PlayingReplies: 0Last Post: 17th Nov 2010, 06:32 -
Phillips DVP5982 vs Phillips DVP5992?
By jarko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jul 2008, 13:41 -
HDV Picture is too dark.
By dj_magic in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Jun 2008, 15:21 -
How to improve dark VHS picture?
By rbatty11 in forum RestorationReplies: 15Last Post: 11th Sep 2007, 19:57 -
Dark picture
By MarioB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2007, 00:14
