File only plays using DiVXplayer, others are green with audio
Problem is using TMPGE to convert to VCD I get green screen.
Set Direct show priority to 3. still green. If below 3 convert doesn't begin.
Downloaded new DiVX 2.5.3 player/codec. No help
G spot says I have 5 codecs...
Divx Pro 5.0.5
Moonlight NicePheratu
XviD MPeg 4
2x DivX Decoder Filter 5.1.1031
What am I missing??? I've spent on/off weeks trying to figure out.
Thanks in advance
Nick
click on the big sticky at the top of this page: Common TMPGenc Problems
https://www.videohelp.com/tmpgenc#problems -
I think from nickgold's post he has already tried the help on there for a green pic.
I wonder if you have too many codecs installed , I have seen numerous posts in the past where people recommend to uninstall your codec packs and start reintoducing codecs one at a time as and when required and see if it cures your problem .
You seem to have 3 Divx codecs installed why not delete them and just install the latest one and see if that works. -
Thank you TeeGee420 the ffdshow was the problem. I got it working.
I was almost going crazy.
Thank you also Andyp1. You were correct the first step I took was to check the TMPGE Problems and Tips page. Maybe we should add TeeGee's advice to that page.
As for the codecs, that did cross my mind, G spot says I have 53 video and 28 audio that might be too many. How many is too many? Any advice? Anyway, it works now. so if it aint broke dont fix right. right???
Exactly! Deal with problems as they arise. Glad you got things working.Originally Posted by nickgold
WOW that sounds like a lot of codecs. But you are absolutely right If it works leave well alone.
TMPGEnc green screen
By BobAchgill in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 17:06 -
How to use green screen with video?
By MitchStevens in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2009, 10:44 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 01:21 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11 -
AVI Divx convert to H.264 White Screen
By livet0ski in forum MacReplies: 7Last Post: 17th Jul 2007, 18:56
