I am a complete newbie...I want to take DV tapes and make my own DVD home movies with sound....I realize individuals have preferences in both equipment and software. What I need to know is at a minimum, what is required for both to begin experimenting with this process at home. I don't want to hire someone...I prefer to learn to make them myself. I've looked at several other post, like in the How to make DVD home movies (very helpful), but can't seem to narrow it down. Are there programs out there that can be compared to "DVD making for Dummies!" How much should I expect to put out for equipment and software? What minimums should I consider in reference to my computer? This is a terrific site...I'm glad I found it. Thanks for any help![]()
try this guide to help you on your way : https://www.videohelp.com/guides.php?link=6
Always check helpfiles/instructions before leaping... -
VirtualDub ....must-have software.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I would search the Capture Cards area to the left as a starting point. Personally I like the Canopus ADVCD-100 because I do a lot of analogue conversions from VHS. If all you wish to do is DV, I think all you need is a firewire port and a digital camcorder. It is pretty difficult to say that you must have a certain processor and RAM and HD etc. as a minimum.
Fill in your Computer Details in your profile and we can give a bit more descriptive responses.If in doubt, Google it. -
IMHO, in order to take DV footage and convert to DVD's you will need ...Originally Posted by chris in fla
1 GHz computer with Firewire port, 512 Mb Ram, DVD writer, 80 GB hard drive. As with most mimimum requirements, higher specs are better. A faster processor is recommended (2 GHz and up), and a larger hard drive is preferred as well (120 GB and up) since DV takes up 13 GB per hour and you can quickly run out of space.
How much you spend depends on the going price for computers in your area. If you're buying new and want to save some cash, I recommend buying one or two notches below the fastest advertised systems. You don't need blazing fast speed for editting video, leave that to the game players, but you don't want to be obsolete in 6 months either
For software you can get some entry level packages like those made by Ulead, or higher level products like Adobe Premier. Read up in the forums to see what other people use. Hope that helps.
BTW, if you're transferring DV footage from a camcorder via firewire you won't need a capture card, just a firewire port."Art is making something out of nothing and selling it." - Frank Zappa
What Hardware/Software do I need?
By Frank W in forum Newbie / General discussionsReplies: 7Last Post: 3rd Apr 2012, 18:30 -
Hardware Mpeg-2 or Software ?
By video80 in forum Capturing and VCRReplies: 24Last Post: 7th Mar 2012, 21:25 -
Hardware corrector or Software
By mark23 in forum RestorationReplies: 4Last Post: 11th May 2010, 04:43 -
Do you register your software/hardware?
By yoda313 in forum PollsReplies: 6Last Post: 17th Sep 2008, 10:53
