I'm just wondering why this is necissary (or if it's not).... Will this increase/decrease the time it takes to "compile" the dvd?
Maybe I'm not totally understanding the authoring process?
http://www.mediachance.com/dvdlab/Help/index.htm
apparently that is how they can check if the source material is "valid" or "compliant" before you go through the work of making a DVD out of it. I think you can force it to use the file without separating the audio/video, but then you risk that it may not work on the DVD. -
It doesn't, but you take a big risk with compliancy checking if you do not.
DVD's that split?
By videobread in forum MediaReplies: 16Last Post: 7th Dec 2009, 10:49 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 01:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 23:35 -
DVDripping everything good up until rejoin
By Xplic1T in forum DVD RippingReplies: 1Last Post: 11th Jul 2007, 00:26
