I'm using Premiere 6.0 to edit, exported the video and audio separately to .avi, and followed the guide with TMPGE for DVD(mpegII) video, but the reccomendation is to use a separate program for the audio. I use Nero 6.xx for authoring, but don't see where I can link the audio with the video for the final merging. I've used TMPGE in years past and just left the audio linked, but I'm just getting back into editing and followed this guide http://dvd-hq.info/Compression.html. Do I really lose that much by encoding the audio with TMPGE? Any thoughts?
Originally Posted by TicklemeBigBird
The first is the fact that MPEG audio is not standard on all DVD players. Although it is supported by all PAL players (and many recent NTSC models), some authoring programs still refuse to add MPEG audio directly to their projects, and will instead convert it to PCM (uncompressed). Since MPEG audio uses lossy compression, the quality that was lost in the compression is not recovered. By contrast, the space that was saved by the compression is lost again. So, using MPEG audio in these programs is a lose-lose situation. The only two formats guaranteed to be compatible with all players are PCM and AC3.
Pretty much EVERY dvd player 2 years or newer can handle mpeg audio with no problems (even the dirt cheap Walmart dvd players). In addition TMPGENC DVD author does NOT convert the mpg sound (either in the mpeg file itself or in a separate mp2 or mpa audio file)to PCM! It burns it as mpeg sound and MOST players these days can easily handle that. Besweet produces excellent mp2 (mpeg sound)sound and its WAY smaller than WAV (PCM) so why eat up all that space on uncompressed sound? Sure if you want ac3 or dts its another story. I suppose it boils down to how high quality the sound is in these avi files of yours. Its like ripping an audio cd. do you prefer just the wav off the cd (a huge file)or can you live with high bitrate excellent quality mp3's? Its up to you.
it also says this:
The second reason is the fact that there are several MPEG audio encoders that produce better quality than TMPGEnc. So even if your authoring program does support MPEG audio, and if you're sure the resulting discs will only be played on DVD players that support MPEG audio, you should still use TMPGEnc only for the video, and encode the audio in a separate application (if you do a quick search on the web for "MPEG audio encoding" you should be able to find several guides about the subject).
That I can agree with. Besweet is definitely better as an audio converter than TMPGEnc.
Help... tired of listening to encoded audio
By pixeltweek in forum AudioReplies: 1Last Post: 18th Aug 2010, 03:31 -
RipBot audio can't be encoded??
By crankharder in forum Blu-ray RippingReplies: 0Last Post: 13th May 2010, 14:56 -
where/when is video encoded on a website?
By grower in forum Newbie / General discussionsReplies: 15Last Post: 13th May 2010, 14:50 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Encoded audio is not good - Add better audio?
By NotSoEasy in forum Video ConversionReplies: 2Last Post: 7th Feb 2008, 19:05
