I recently purchased the LG 4081B 8X drive and after looking on the net i found out i had to update the firmware which I did. When my computer boots up it will say A101 which tells me its updated. Also when I run the update program it says my current version is A101. I was wondering why I still cannot write at 4x. I have used Nero 6 and Easy Cd Creator and still only 2X. I have 4X media which I want to write to. One possible explanation I can think of, is that I did not have my burner plugged as the Master on the second chain because I have my Linux drive as my Master when i updated the firmware. Wasn't sure if that was going to screw anything up in terms of my dual-boot. If you know please let me know.
Im running windows Xp pro sp1, p4. 1.8ghz, 769mb SDram, etc....
Ne help is appreciated!
I had the same difficulties. I changed media brand and voila burnt at 4 speed. Was using a el-cheapo which stated 1-4X but obvioulsy wasn't.
goto dvd media on your left and check the media that can write at 4X with the 4081 and use those instead.
Firmware update after regionhack?!
By little demon in forum DVD & Blu-ray PlayersReplies: 8Last Post: 28th Nov 2009, 00:50 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 14:52 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 23:46 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 07:56 -
DVR1112D firmware update?
By videobread in forum DVD & Blu-ray WritersReplies: 3Last Post: 15th Sep 2007, 21:02
