Every time I try to backup a film using DVD Shrink, I get an error, saying that it could not read the file, and the sector is encrypted. This happens whilst the disc is being analysed at the start. I don't think there's anything wrong with my discs, I've backed them up before without any problems, although I have since reinstalled my operating system, so i'm wondering if there's a setting I need to change?
Also, perhaps more importantly, I have also upgraded my burner to a Pioeer 107 since I last backed them up.
Try playing the DVD first in WinDVD or PowerDVD, then load DVDShrink.
If that doesn't work, rip to the HDD first with DVD Decrypter. -
This sometimes happens to me aswell..
i find if you reboot and wait a while then after a few tries it will work..
i know it dosnt sound too practical, but it does work... -
HI
BECUSE YOUR DVD MOVIE IS CSS CODE AND DVDSHRINK NOT ALWAYS CAN BRACK THE CODE SO YOU CAN USE
1 DVD DECRYPTER OR
2 USE THIS ONE IT ANYDVD 40$ WORT IT
THIS ONE WELL FIX ALL YOUR PROBLEM
AND DVDSHRINK WILL "THINK" THAT DISC YOU PUT IN YOUR DVD-ROM
IS WITH OUT ANY PROTECTION
USE IT ...
Roxxan
TO BE OR NOT TO BE IS THE SPEED YOU BURN
Copy Protection on DVR to DVD-R
By scarecroe in forum DVD & Blu-ray RecordersReplies: 15Last Post: 6th Nov 2011, 08:27 -
Copy protection problem
By Kirsi in forum Capturing and VCRReplies: 2Last Post: 29th May 2011, 12:25 -
Why does DVD Shrink add RC protection to its files?
By takearushfan in forum Newbie / General discussionsReplies: 5Last Post: 7th Feb 2010, 13:32 -
Copy Protection from a DVD recorder?
By tonyaldr in forum DVD & Blu-ray RecordersReplies: 16Last Post: 2nd Nov 2008, 15:51 -
DVD video copy protection
By efiste2 in forum Authoring (DVD)Replies: 2Last Post: 6th Oct 2007, 18:31
