Hi,
I have been using MAESTRO for a long time. It is a great tool that can do anything. I heard Sonic DVD Producer implemets the same idea giving some extra features and a much nicer GUI.
Did anyone try this application? A brief comparison will be very usefull.
Thanks,
look on thier web site for a feature list .. its supposed to be very good.
ussually only sold as part of a hardware package though i believe..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
A feature list is very impressive, but I am looking for somone's actual experience.
Maestro is IMO overall better product, but Producer comes very close. Plus, there are some fine things in Producer that you can't do in Maestro (like direct burning to DVD before compiling, you can import mpeg/VOB files from DVD/RW...)
is there going to be a big learning curve to DVD Producer from Ulead's DVD workshop?
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 22:11 -
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 02:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
Sonic won't recognize DVD, computer does ...
By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 14:06
