Hello
I want some help on how to capture a still frame using the webdvd object or other way to play dvd in visual basic. I know that the webdvd has the capture method but I want to capture the frame and save to a file without the user interaction.
Anyone has any idea on how to do this?
Thanks![]()
Well I may be way off on this, but all the objects I've ever worked with in VB that has a method defined can be manipulated through the code. I've never worked with nor seen the webdvd object. The way you talk it has a user interface that allows the user to select "capture frame"? If so, it should have a way to do this through the code at any time you want to do it. Like clicking a command button. "Command1_Click()"
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Still Frame and Field Capture?
By swingmaster in forum Newbie / General discussionsReplies: 1Last Post: 10th Mar 2009, 09:28 -
All Frame's Capture to show In one big Pic . ??
By lostnucleus in forum Newbie / General discussionsReplies: 11Last Post: 28th Feb 2008, 04:24 -
image shift in frame with Virtualdub capture
By Knightmessenger in forum Capturing and VCRReplies: 0Last Post: 27th Aug 2007, 00:16 -
dazzle video capture frame skipping
By VistaXP in forum Capturing and VCRReplies: 2Last Post: 2nd Jun 2007, 18:00
