Because of its high regard in this forum, I picked up an ADVC-100 for capturing from my Sony Hi8 camcorder. I have a lot of film I want to put on DVD. I am having a real time trying to capture at DVD resolution with decent quality. I have tried Ulead VideoStudio 7 and DVD MovieMaker, Adobe Premiere 6.5, WinDV, and Windows MovieMaker. With every application except MovieMaker, I got lots of narrow horizontal black lines. MovieMaker gave me good quality, but I can't make a DVD with MovieMaker and the MS codec is incompatible with any authoring app I've tried.
Any help/guidance is appreciated. Thanks in advance.
Have you actually encoded and burned it to dvd? What you are seeing may just be a result of playback...
I just got through reading some info on www.digitalfaq.com. I'm thinking those are just interlace lines.
This is my first foray into DV capturing, which is basically what the ADVC-100 is doing, an external convert from analog to DV. I'm going to give VirtualDub a whirl also. -
Originally Posted by VinnySem
I doubt you'll have any look with Virtualdub.
'Capturing' with the ADVC-100 is the same regardless of the software you use.
Try DVIO, if that doesn't work, nothing will.
To echo the unanswered question from upshot; have you authored and burnt to DVD-r yet?
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 13:21 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 08:39 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
