I am encoding files with TMPGEnc, they are non-standard MPEG-1 and whatever I do the file size never matches what the wizard tells me. For example a recent file I encoded told me the resulting file size would be 80mb and yet the final file was 120mb - this makes it very difficult to code to the right size to fit a certains number of videos on a CD-R. Does anyone know how to fix this?
HELP!
You are in breach of the forum rules and are being issued with a formal warning. Please wait a few days before bumping your topic.
/ Moderator Baldrick -
OK this is really strange, even if I lower the bit rate substantially - eg. from 700kbps to 300kbps the resulting does not change at all - it is always the same size!! What is going on here?
I agree 50% bigger is a pain but you'rw orking with very small files sizes here, you nee ot give TMPGEnc a chance!
There's a bitrate calculator in the tolls section to your left, you might have more luck with it.
Oh, and a friendly peice of advice, two posts within an hour of your initial post won't win you many friends, it contravenes the AUP and pisses people off.
Try editing your post instead
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Geeez it's hot in here.
3 posts of the same question?
I think you need to unlock the template. -
Agreed...load the unlocked template
No, I'm from Iowa. I only work in outer space. -
You must change the stream type to MPEG-1 VCD(non video standard), under settings->system(in wizard under step 3 under other settings->system). If the stream type is MPEG-1 VCD it will be the same size even if you change the bitrate.
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 02:55 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 20:48 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 15:30 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
