I use a notebook with the following spec:
P4 Windows XP , 1.6 Ghz, 256 Ram, 19 Gb available hard drive space, new bus firewire card IEEE 1394, and sony digital 8 TRV 460 camcorder.
I tried to capture home video but the audio is not captured, the video is flickering, really bad using WMM and DVIO. I couldn't even play back the tape using WMM.
However, I downloaded a trial version of Ulead Media Studio Pro 7 and used the video capture feature. Play back was excellent as well as the video capture. Created a small mpeg file with the captured avi file and it plays fine in media player. However, when I tried to play the avi file in media player, the quality is flickering and ther's no audio. This same avi file plays fine using the video capture of media studio pro.
Other mpeg files I made before from analogue capture (using matrox marvel G400 under Windows 98 from my old computer) play fine in media player in my notebook.
Any one can shed a light as to why is this hapenning and suggest a solution? (other than buying MSP 7 of course)
Thanks,
Mourad
are you capturing in type 1 or type 2 avi? it should be type 2. some media players cant read type 1 right.
To tell you the truth, I didn't know which type I used. I did some tests using DVIO and with type 2, I'm getting the audio but the video is still the same. However, the captured type 2 avi file plays fine using Ulead MSPro 7. Must be something wrong with my media player, many thanks for your input.
Video capture, editing & redndering in 1680x1050 - BIG PROBLEMS
By casparticus in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2011, 17:57 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 11:40 -
Newb questions - re. HD&MiniDV Camcorders & Capture
By The Big Cheese in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Jan 2009, 18:21 -
WMM recognzes camcorder but DVIO and WinDV don't?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Dec 2007, 05:34 -
WinDV or DVIO? Differences?
By w@ntonsoup in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 13th Oct 2007, 16:51
