when we have seperate streams for video(m2v) and audio(mp2)
is there any software that when it plays the m2v to play mp2 together?
or any other way to play the streams together without the need to multiplex them.?
rgrds
Results 1 to 10 of 10
I Think you can do that with Media Player Classic, but not 100% sure about it
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
hi m8
just tried it.
yes it does work but not with all files,i dont know why.
i have 12 files(6 video 6 audio ) in the same folder and the same names
for m2v and mp2 but it works only with the 4 of them!!!
ok ,it doesnt hang at least..and still plays only the video.. -
ok i found the prob.
i have to restart the program before i change file and then it works with
all files.
its ok,better than nothing.
thanks a lot. -
Glad I could help out! 8)
Best Regards,
Sefy Levy,
I wanted to know another program (other than Media Player Classic) to play m2v and mp2 files together. Because when I load a 4 gb file on MPC, and I want to go to the end of the movie, it get's out of sync.
The only other player i'm familiar with would be VideoLAN (VLC) which can also play all file types
Best Regards,
Sefy Levy,
Hi Sefy
I've just downloaded the software but I can't find the option to open 2 files at the same time (like de m2v and mp2) I tried the Quick Open and the Open File but I couldn't find where do I set up audio sorce and video source. Could you help? Thanks! -
Oh, I thought you just wanted to play M2V files
I'm afraid I don't know of any other program
but I do have a "quick" solution for you, if the large file is an M2V file, you can use DVD2AVI to create a small D2V file and MPC can play that and you should have less problems accessing the 1gig file.Email me for faster replies!
Best Regards,
Sefy Levy,
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 07:22 -
black video when playing back .m2v (premiere CS3)
By morr1s2 in forum EditingReplies: 2Last Post: 5th Aug 2008, 09:28 -
edit m2v files?
By SUPERIOR in forum EditingReplies: 2Last Post: 16th May 2008, 03:42 -
m2v file stops to display frames during playing
By Fendervr in forum Video ConversionReplies: 2Last Post: 22nd Aug 2007, 13:43 -
ts files into m2v or mpeg2
By vertical in forum Newbie / General discussionsReplies: 124Last Post: 21st Jun 2007, 14:12
