I capture my Home movie's with Pinnicle 9 and I do some edits and add transitions and then I make another avi file when done and then off to render to mpeg2. The question I have is when I get done editing and I make another avi file it takes about and hour to render it again. I use the DV Codec but I see I can use a few other one's like Cinepak Codec by Radius or the Panasonic one would this make it faster or will it be a better quality or is it a better way to do this? Thank's for any help you all can give.
I would stick with the DV codec. If your considering changing codecs, then you just as well go to a high bitrate mpg2. But if you have the hard drive space stick with DV avi until your ready to render your dvd.
Advice: To make my Laptop edit better.
By Cvintila in forum EditingReplies: 14Last Post: 9th Oct 2010, 22:57 -
To edit an existing menu, or make a new one ?
By Chainsaw_1 in forum Authoring (DVD)Replies: 5Last Post: 9th Mar 2010, 17:50 -
Question how to edit several minutes of avi at frame level
By jimdagys in forum EditingReplies: 9Last Post: 23rd Dec 2008, 19:26 -
Question how to make srt/avi subtitles bigger when playing in DVD player
By jimdagys in forum SubtitleReplies: 6Last Post: 24th Oct 2008, 01:10 -
Question how to time idx/sub files and use them (with avi) to make DVD
By jimdagys in forum SubtitleReplies: 11Last Post: 15th May 2008, 20:35
