hi folks,
i've several DAT-Files converted via VCDGear to MPEG-Files, i want to burn them to a single DVD to avoid changing the CDs
Is it possible to improve the quality of the videos (except changing the resolution) ?
I Doubt you can improve the quality, more likely if you re-encode you will trash the quality even more, cause that will add more compression artifacts
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
You can use Procoder or TMPGENC with some noise reduction filters to improve the quality. But the new file must be 352x480 with a higher bitrate. It can happen, but you must be willing to increase the disc size? What's more important? Quality or discs? I always go with quality myself. It will take what it takes.
Improving Old Footage?
By PHNeedsHelp in forum EditingReplies: 1Last Post: 1st Jan 2012, 10:50 -
What to expect from improving VCR?
By bigass in forum Capturing and VCRReplies: 11Last Post: 17th Sep 2010, 11:41 -
Any suggestions on improving this video?
By Des in forum RestorationReplies: 25Last Post: 14th Sep 2010, 10:47 -
Improving quality?
By BwanaP in forum Video ConversionReplies: 30Last Post: 19th Jan 2010, 22:03 -
Improving Hi8 Look
By rvalich in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 17:43
