Hi, I want to capture a vhs movie I own to dvd. The capture would end up being one file. Is there a simple and easy way that I can get it to have scenes and maybe even a menu? Would it involve reencoding or just typing in the times of the scene changes? Would they be seemless when the movie is watched start to finish?
Thanks.
Mongoo
I take it you have a capture card in your pc.
Capture using whatever capture software you have on the pc - Ulead, Win DVD Recorder etc. Depending on the eventual size of the file capture at the highest rate you can. i.e. DVD
Author with Tmpgenc DVD Author. This is a very simple progam to use and will allow you to have chapters and moving menus. The movie will play seamlessly from the start or from whichever chapter you play from.
Jim
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 06:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 13:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 21:47
