Can anyone and everyone give me settings that you use for optimal quality when converting avi to mpeg2? Just trying to get a general idea of what the most common settings are for the best quality conversion. Thanks.
Depends on the AVI specs. Length, size, framerate, interlacing, resolution. All those factors determine the possible quality of the AVI, which in turn determine Whether you use Full D1, 1/2 D1 or 1/4 D1 resoltuion in TMPG.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I guess there is no one setting that works best. I was kinda hoping to avoid going through a trail and error thing. I also guess there is no way of really telling which encoder is better either as one may have differing views than another in terms of percieved quality.
Originally Posted by Gazorgan
i would say the same thing"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
M'kay here's mine:
1 or 2 CDR AVI's: 352x480 Interlaced at 23.96 with 3:2 pulldown (for 23.97 AVI's, otherwise it's 29.97), 2-pass VBR, 1000 min, 2500 Average, 6000 max. Center, keep aspect ratio. I also use a lot of 352x240 @29.97 fps progressive encode. For film sources there is absolutely no difference between the 2 (go 2-pass 300 min, 2000 avg, 4000 max).
2 (very short movies), 3, and 4 CDR AVI's: 704x480 Interlaced at 23.96 with 3:2 pulldown (for 23.97 AVI's, otherwise it's 29.97), 2-pass VBR, 1000 min, 4000 Average, 8000 max. Center, keep aspect ratio.
Audio: I use AC3 if it's there, otherwise MP2 at usually 192K (or lower to match the source).[/b]To Be, Or, Not To Be, That, Is The Gazorgan Plan
Optimal settings for conversion
By airwolfUK in forum Video ConversionReplies: 1Last Post: 17th Feb 2011, 15:08 -
Do you always choose the first poll choice in a poll?
By yoda313 in forum Off topicReplies: 5Last Post: 15th Jan 2009, 20:49 -
MKV conversion settings help
By pianoman0723 in forum Video ConversionReplies: 1Last Post: 6th Sep 2008, 11:39 -
HD->SD Conversion - Settings Help!
By Russell_hq in forum Video ConversionReplies: 0Last Post: 20th May 2008, 09:33 -
Whats our DVD player POLL POLL POLL
By clevername2000 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 2nd Nov 2007, 23:36
