Hi all, I have done a search and have been unable to find the answer so here it goes:
I have a Mac G5 with a Superdrive. I have received both DVD - R (TDK) and DVD + R (Memorex) through trading that have played on my home DVD player and on the Mac. I tried to burn some copies (onto both + r and - r) and those copies will play on the Mac but not at home. the process I used was to copy the audio_ts and video_ts to the hard drive, insert a blank disc, drag the files to the disk, and burn. I am sitting on some DVD's that I need to send back, so any help you can send my way would be greatly appreciated.
Jeff
Although this is in the wrong forum, I will attempt to answer it. What program are you using to burn to the blank dvd+r? If you are using Toast 6.X you have to burn it as data with the AUDIO_TS and VIDEO_TS folders in the compilation. Check the Mac Video Forum as I am almost certain this was discussed there.
You need to burn the DVD in UDF format and I'm not certain that the Finder burn does this with DVDs. You may need Toast. With it, the process gets even easier because you can use the Copy option to duplicate the DVD (assuming it isn't copy protected).
sorry for putting this in the wrong forum, thank you for your comments. I will try the disk image first and than start looking into getting toast.
Send back? Hopefully you mean back to your dvd rack in your living roomOriginally Posted by jdopj
Pretty sure its been explained, but
You have to make a UDF image of the files you want to burn, then burn that image using disc copy.
Pretty straight forward. DVDImager is an app that can handle that
Basic DVD Burning for Mac
By The Monkees in forum MacReplies: 8Last Post: 9th Mar 2010, 17:30 -
DVD-Audio disc burning on Mac?
By karipu in forum MacReplies: 12Last Post: 25th Apr 2009, 18:48 -
Avi to dvd Problems on a mac
By Cruz240sx in forum MacReplies: 6Last Post: 19th Apr 2009, 19:47 -
Burning DVD with subtitles on a mac
By villa99 in forum Authoring (DVD)Replies: 1Last Post: 1st Dec 2008, 13:23 -
Burning dual layer dvd-r from mac the ripper
By alforra in forum MacReplies: 11Last Post: 18th Apr 2008, 21:08
