Hi guys please look over these settings for a vcd template ntsc widescreen and tell me what changes i should make for better quality. (only vcd changes please, thats all thatll work in grandma's dvd player and in mine)
Soure: taped on cannon mini dv at 16:9. captured and edited in studio dv 7 from pinnacle, avi is 720X480 29.97 frames with pcm 16bitStereo 48khz
TMPG Settings
Mpeg Setting
Video
Motion Search Precision HQ Slow
Advanced
Video Source Type interlace
Field Order Bottom field 1st
Source Aspect Ratio 16:9 525 line (ntsc)
Video Arrange Method Full screen Keep aspect ratio
GOP Structure
I 1
P 10
B 1
Detect Scene Change Check Marked
Quantize Matrix mpeg standard
Output YUV data as.. Check Marked
No motion search... Check Marked
Soften Block noise Check Marked
Intra block 35 Non intra blocked 35
AUDIO
Channel Mode: Stereo
Thnx for all of your suggestions, i have compiled those settings from other peoples templates but im not sure if its the correct way to go given my avi source, or maybe a suggestion to improve upon the quality of the vcd.
Shao
