  1. hi i cant play any movies on my machine xp pro. tried wm player...winamp...and cant even load a movie into tmpge...the system just hangs (hour glass goin round and round) it was fine around 5 days ago.. dont know whats wrong..were do i start remove codecs and reload em....remove media players and reinstall em ...or is it something a little more easier than that....or more complex.....any ideas were to start the troubleshooting would be appreciated thanxs.....p.s i cant even take my pc back to a restore point ????????? thanxs again
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    That's a pretty general way of defining your problems. If you could give the specifics of some of the movies that wont play (mpg/avi/codecs & cetera) someone might be able to help you...
    /Mats
  3. it wont play nothing avi mpg divx etc thanxs
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The automated NOOB response:
    We are not a helpdesk. Attempt to help yourself first and we can offer alternatives.
    To be constructive, It seems strange that not 1 file will play in WMP. That sounds to me like codecs could be a problem. Try reinstalling them first. The fact that you can't go back to a system restore indicates that there might be something wrong with Windows itself. AS a last resort, reinstall windows, and I mean the long way. Reformat first and reinstall from scratch. If this is not an option, drop your box into you local computer store.
    If in doubt, Google it.
  5. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Try an audio file
    pick one try all
    1. wav
    2. mp3
    3 midi
    and tell us what happens..
    Alternately download a version of VLC from Videolan.org that doesn't install and try to play a clip by dragging it to vlc 6.0 or less
    upon re reading this because you're douubly negative ..you then have no problems...! Congrats :-)
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Installed any cool codec pack lately? Then I suggest you follow jimmalenkos advice, and go for a full reinstall.
    /Mats
