Hi all,
Having recorded a VR mode RW, I wanted to play/edit/copy some parts to my PC hard drive, but windows does not recognise the format.
Is there any software that can enable me to read and edit on PC HDD these VR disks ?
TIA
If they are +RW....say from a Philips machine....the two latest versions of DVDShrink will recognize the data. DVDDecrypter also recognizes them easily....I use IFO Mode with Stream Processing enabled and remove the subtitle(that is the Philips menu). Then I use TMPGEnc DVD Author to add chapter markers....etc etc.
OR....I also use Ulead Movie Factory 2 to edit right onto the original RW disc.
It's best to know the exact position of your chapter markers BEFORE using DVD Author or MF2. It is MUCH faster to type the time into the programs than using the slider....than way SUCKS...at least on my computer.
I don't really "EDIT" my +RW's on my computer....I do that on the machine prior to it hitting my computer.
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27 -
What is Batch mode editing in Virtualdub?
By gargoyle_xlvii in forum EditingReplies: 4Last Post: 22nd Feb 2008, 14:38 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
