hi all
i have been told that another reason my dvd writter might be burning dvd's wrong, ie i get blocky bits in the last 10 minutes might be caused by not having the upto date firmware for my burner,
i found this link http://forum.rpc1.org/dl_firmware.php?download_id=1603
it is the page for me to get my firmare but i am really new to this, and it says it could be dangerous if you do not know what your doing, has anyone done this before and it is easy??
if anyone could look at the above link for me and maybe take me through it i would be really grateful as i dont even knw which one to download!
Thanks for all your help
Chris
Hi Chris,
first of all, try different Dvd's instead of updating your FW, in my opinion your Prob depends on your Media (or Authoring).
If you still plan to update the FW of your Burner, then use original FW- updates from the manufacturer's Page (not the Page you mentioned),
but if you are not familar with all this stuff keep your finger's off it, you might damage your Burner!
Insignia NS-BRDVD2 / NS-BRDVD3 / NS-BRDVD4 -region hack firmware question
By Jack Torrance in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2024, 18:47 -
DVP5990/37 Firmware Upgrade and Planned Obsolescenc Question
By emunity in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Jan 2016, 18:52 -
Panasonic Firmware question
By vetski179 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 19:30 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 06:56 -
question about firmware destroyed mp3 player
By jimdagys in forum ComputerReplies: 1Last Post: 13th Sep 2007, 05:10
