Help,
I have looked but can't find anything in here to help. I have downloaded a file from the net which is in AVI format, the file is in two cd's i need to know how to join the 2 back in to 1?? and do i convert first or later?
any help would be appreciated![]()
Use virtualdub. Open the first file and then go to Append Video Segment in the File menu.
Convert after this. You don't specify what you want to end up with so I can't tell you how to convert it.If in doubt, Google it. -
Read my response below
https://www.videohelp.com/forum/viewtopic.php?p=855031#855031
Can be applied to your problem.
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 20:33 -
joining mp4 files
By slgorin in forum EditingReplies: 3Last Post: 3rd Sep 2009, 17:47 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Joining 2 mpeg files together
By efiste2 in forum EditingReplies: 3Last Post: 28th Jul 2007, 07:37
