at first CCE was running fine, now whenever i start the program, it starts minimized and it just stays like that.
im using CCE Trial version 2.67
i've reinstalled it 3 times and still no luck
Try right clicking on the taskbar icon of cce when its minimized and choose restore.Also look for the taskbar of cce in the corner of your window somewhere and click on maximize.
Try System Restore on XP. I had the same problem a while ago, and this solved it. Easy to do, if you run on xp of course.
Maybe there are even easier ways, but I sure didnīt figure them out
"This is true in all walks of life: Man takes care of the quantity, woman the quality." -
go into the regedit Hkcurrent??, and software, custom technologies, ? sorry I am not sure of the exact file in regedit but there are four Pos entries. delete these and restart cce and it should work. I just searched doom9s cce forum today and got this fixed myself.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 21:14 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 13:53 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 15:41 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27
