I've been trying for several days to write a DVD with Nerovision Express 2. The disc I'm trying to burn has four 25-minute videos on it, and a menu. I'd chosen standard video quality, and to transcode my video to 720 x 480 with the audio as AC3. The earlier version I'd been using would crash early in the process; I downloaded and installed the latest upgrade today. It went much farther before crashing with the following error recorded in its log:
"19:40:11] DVDEngine DVDEngineXceptFilter(): Caught SEH Exception 0xc0000005
[19:40:11] DVDEngine DVDEngineXceptFilter(): Exception was raised from C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax at RVA 0x00035bc8"
Any clue as to what might be causing this error? My machine is an Athlon XP 2800+ with 512MB memory. I can provide any other info necessary to help with the problem determination.
Thanks!
yeah i been having problem with my NV too. When i tried to burn the files, a message box pop up saying.
"Unable to create the disc structure: Transcoding of videos failed
Burn process failed."
They give me txt file to see what the problem, but i don't really understand it.nothin is wat it seez -
Make sure you are actually using NVE 2 there have been problems with NVE 3 with the burn at once option. On the burn options menu look under recording settings and uncheck it.
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 8th Aug 2008, 23:45 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 10:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 07:00
