Question...
1: How do you link a Movie file to First play? Do you have to redo the connections and then ad Movie Menus? Or do you Click and Drag your movie from the Asset bin to the First Play logo on the connection screen?
2: When I have multiple Chapter screens and I burn them to DVD they are coming out in reverse order...is there something I need to check to make sure the chapter screens are in the correct order?
3: IF I wanted to make a Flash or SHockwave presentation with my company blurb on it......can I import a Flash, or Shcokwave file to acomplish this!?!@
Peplogic
Originally Posted by Peplogic
3. I don't think so, unless you exported it as an .avi file and then converted to a dvd-compliant file.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
2. If you are menu edit mode, right click on an object, and you get the option to set as first first button. If you do it, it becomes first button, and others are all renumbered. The numbers are in little yellow boxes next to the buttons. If you do another one, it becomes 1, and the old 1 becomes 2. You can keep going, and renumber you whole menu this way.
Randy -
2) Are you saying that the chapter menus are in reverse order? If so, then it's how they were linked together by you. Make sure you didn't link them backwards.
I used the Chapter wizard and template to come with the menus....the wizard split them up to two menus and then linked them...i didnt find out that they wree linked backward till i burned........
Randy
More dvd lab questions
By sterankin in forum Authoring (DVD)Replies: 12Last Post: 16th Aug 2010, 16:13 -
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 17:52 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 01:39 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 06:45 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 07:52
