Howdy,
The title says it all. I am trying to author a disc with TMPGEnc DVD Author and the 2 titles that I want to add are 23.976 fps. When I input them Tmpg says that the frame rate 23.976 cannot be used for a standard DVD. I thought that this was the frame rate that all film based material is transfered at. I converted them to MPEG-2 from XVID files using TMPGEnc Plus and ended up with an mv2 and wav files.
This is my 1st time to do this with the TMPGEnc stuff instead of Nero 6. The main reason that I got the TMPG Author stuff was because one of the files kept failing in Nerovision.
Any help or guidance will be greatly appreciated.
Thanks,
M
Use pulldown.exe with gui to apply 3:2 pulldown so you can import them in tmpgenc dvd author.
Frame Rate/23.976 vs. 29.97
By mltwitz in forum Video ConversionReplies: 11Last Post: 20th Dec 2012, 08:23 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15
