  1. i love the quality of fairuse for the divx but for some reason i cant get no audio from it can someone please help me..... i live in the us if anyone needs that info i have both the 0.39 and the 0.40 versions and cant get audio from either one of them.........thank you
  2. Member Gritz's Avatar
    Feb 2003
    Hmmm ..... the first time I used it I came up with the same thing ... I think I was too much in a hurry. It will allow you to create the copy without selecting any sound. When you get to the screen that allows you to select between Xvid and DivX (and I always select the Xvid) and after you select that .... then below that is the audio. You click on the audio target (sorry I don't have it in front of me) and up pops what it found ... (AC3 or something) select that, click ok and it will appear in the target area below and you're set to go. After that just follow the prompts ... "NEXT", I think, and go eat supper .... or click on "Shutdown Computer When Finished".
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
