Hi i am trying to convert an svcd to dvd using procoder but every time you try to import the mpg file it just freezes up.
All the correct codecs are installed and i can play the clip in media player also the program seems to work ok with avi files.
Has anyone had a similar problem and got over it and ifso how did you do it.
any help appreciated
go to the registered user section of canopus and there is a program you can download to enable reading mpg files IF you have a problem ..
you must log in first with your serial number and such to download it ..
this ussually takes care of the problem -- in extreme cases you must un-install procoder , windvd , powerdvd and reinstall in a different order and/or still use the canopus mpeg reader ..
i couldnt find much info about this on thier forum (reg'd user also only) but have had the same problem myself ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I use procoder and no problems....
BUT, first time when I installed it I had a problem, it did open the file, but when I pressed the Target button, suddenly everything went wrong.
the problem was one of my codecs pack...called nimo. SO it might be a codec problem.
try this, try uninstalling every codec and programs working with video files, and install first procoder.
Canopus Procoder: chapters in DVD-export? How?
By Lippy Lipstick in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2008, 05:09 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 07:56 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 21:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
