My dvd-rom suddenly rips dvd's in only 2.1x, it doesn't increase speed at all. It did before, so something must have happened, (maybe i've accidently change some setting somwhere??) By the way, my dvd-burner rips at the same low speed... Anyone know what could be done to fix this?? Thanx in advance!! Its a Samsung DVD-ROM and a Pioneer 106 writer..
Are you running Windows XP? If so right-click on My Computer and click properties. go to the hardware tabe and open the device manager. expand your IDE controller list. Right click on either your secondardy IDE controller and choose properties. go to the advanced tab. this is most likely the controller where your DVD drives are located. the transfer mode shoud be set to DMA if available and the current mode should be Ultra DMA 2. if its set to PIO instead then that is your problem. XP likes to switch it on you from time to time. just another bug in the system. to fix it Right click on the IDE controller and choose uninstall. it will prompt you to reboot. when you reboot windows will have to redetect the IDE channel and will be forced to try DMA mode again. that should fix your problem. you may need to do this to the Primary channel too if by some reason you have a DVD drive on that.
DVD ripping incredibly slow
By moults in forum DVD & Blu-ray WritersReplies: 12Last Post: 18th Jul 2010, 16:31 -
Very slow DVD ripping in Windows 7
By stephens in forum DVD RippingReplies: 16Last Post: 5th Mar 2010, 10:39 -
Question about ripping when internet speed is too slow
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 03:49 -
DVD ripping/burning very slow
By happy.hrvat in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 18:24 -
Slow ripping
By Jikchung in forum ComputerReplies: 1Last Post: 15th Dec 2007, 16:23
