I'm going to order a 100 pack of Riteks. The place I'm going to order from have lots of different Ritek G04: Ridata, Ridisc, Ritek landscape,Ritek overprint and Ritek Printable.(http://www.discatonce.se/sv/dept_14.html). They all cost about the same 1,5$. So Which of those should i choose?
My first choice seem to be the Ritek landscape, because they are made directly by Ritek. Have you good experience of these discs?
I would go for anything but the overprints, as I have found them to be less reliable than normal discs
the only one i have tried was RiData and I havn't had a problem with any of the 25 discs that came in the 25-pack spindle
If I maid a forum search on Ritek landscape I only found one post. If I search for Orange top I get lots of hits. However I don't think those are the usual Orange top, because those discs should not be overprinted. I'm I right? Have anyone test this ritek disc?
I use these orange tops exculsivly....
I've used the orange tops (ugly as sin) and the matte silver tops. Haven't had any problems with either, but for asthetic reasons, I avoid the orange tops when possible.
disturbed1 wrote:
There IS a super grade, which is for OEM use. There is a grade that doesn't meet QC standards that gets over printed (usually orange with moutains).
I guees he mean those Ritek landscape. So is this some sort of lower grade Riteks or what? If thats the case it may be better to stay to the ridata or ridiscs?
Trying to choose a new camera
By jlbgt2005 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Jun 2010, 17:41 -
Which notebook you would choose from these 2?
By alintatoc in forum Off topicReplies: 1Last Post: 27th Jan 2009, 21:00 -
dgindex what to choose
By cd090580 in forum Video ConversionReplies: 1Last Post: 29th Feb 2008, 17:33 -
How to choose a camcorder?
By beavereater in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 26th Jul 2007, 07:14 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 10:41
