Hi, I'm new to the whole editing thing. What I'm trying to do is edit movies I record from my digital 8 camcorder and send them back to blank tapes.
I recently got Pinnacle studio 8.4 and it works great for what I want to do. Well, it works great if it would just do what its suppose to do.I have 2 problems with it.
1) It won't make the 6 minute movie I'm working on. It won't send to tape or avi. What happens is that it starts to work and then it gets hung up on a scene and won't go any farther. One example of this was a short 1 second clip I had slowed down to 1/10th of the real speed. So I cut that out and then put in a still. Then it worked. I thought it was the slow-mo but it gets stalled at regular scenes too. Theres no rhyme or reason that I can see.
2) The second problem I have is that when I add music to a sceen and edit the leagth of the sceens. The music completely disapears never to return untill I close the program down. The odd thing about this is that it did work originally but then all of a sudden stopped.
Can anyone help me with this? I really think pinnacle studio 8 is great, or can be great if it would only do what its suppose to.
Thanks in advance.
Mongoo
Your using ver 8.4?
Use thier upgrade patch to ver. 8.10.4c
http://pinnaclesys.com/docsupport1.asp?division_id=1&langue_id=7&product_id=577&produc...e=&page_id=450
If you still need help with Studio, either post back or go here.
http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&SectionID=143&lng=1Geronimo
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Problems Capturing HDV into Pinnacle Studio 11+
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 08:58 -
Pinnacle studio 11 capture problems...
By bla4free in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2008, 10:09 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
Pinnacle studio 8 capture problems
By bimfi in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2007, 15:27
