i`m having troubles with my audio after converting 2 divx movies(BLOW & DRIVEN).After converting to svcd using tmpge.nc ver.f the audio does no play but yet it does on the divx file.what can i do to correct this problem?can someone please help me.thanx.
FUSTRATED IN CANADA!!!!
Have you tried splitting the audio and video into two separate files than rejoing them in the encoding process with TMPGEnc?
or try to correct the audio with virtual dub
Audio-Full Processing Mode
Video- Direct Stream Copy
Save Avi
Then use tmpg to convert to mpeg
works for me all the time
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 11:08 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 06:48
