How did you mux the mpeg 2 video with the AC3 file in Tmpgenc?Originally Posted by Nelson37
NEVER MIND![]()
Results 31 to 43 of 43
Thank You & Have a great Day! :)
reman -
I've never yet run across a player that won't accept mp2, and since I only use dvdauthorGUI, I'm limited to that. Not a hell of a lot of difference in filesize compared with ac3, and never had sync issues using ffmpeggui. Any particular reason you won't do a test using mp2?
As for a source with ac3, you can use Ciler's ac3tool to normalize and extract to wav, then use ffmpeggui. This produces satisfactory output without the low audio problem. All freeware.Pull! Bang! Darn! -
Too bad, and sorry you had to answer that question twice- didn't read closely enough.
Maybe best to just get TDA (or some other authoring prog) with the plugin and save your time, especially if this is your business. (How necessary is it to have menus on this particular project?)
So Pinnacle acquired Dazzle, and also therefore DVD Complete? You have my condolences, no ac3 support will be forthcoming, ever.Pull! Bang! Darn! -
I've tried using both MP2 and AC3 audio…I agree, MP2 has no sync issues (AC3 does for me)…the problem is, I've tried two different methods (TMPGenc which I know is crappy, and Pinnacle) and both sound inferior if listened to through headphones or if you up the volume on a quiet passage. Does anyone know of or can recommend a software that does QUALITY MP2 conversion from .WAV?
Aside from the sync issue, my AC3 has low volume (not to mention all the steps involved). I use VirtualDub to create a WAV from my AVI, FFMPEGUI to create the AC3 from the WAV, mux the AC3 with the MPG using TMPGenc+, then render using TMPenc Author (though I could just skip the muxing step and do it in Author, but not sure what other pros/cons may be involved as far as quality or sync issues).
In order to compensate for the low AC3 volume and sync issue, I have to up the volume in VirtualDub to 187% when creating my WAV (using this % matches the original AVI volume, and use an offset of -110ms to correct sync. I don't like increasing the volume that much because it may become distorted, but don't know of a better work around. I'm curious if anyone else has had similar and can maybe recommend some ideas. Thanks. -
Originally Posted by dwiesel
YES! The volume is much lower. Sucks. BeSweet's latest version (and the underlying software) DOES make the proper AC3 files now. You have the choice of BIG or Little encoding. BIG is correct for DVD specs...right??
I usually use an MP2 file. I recently tried the AC3 encoding and find nothing special about it.Thank You & Have a great Day! :)
reman -
Reman…thanks for the response….guess I'm not alone! You mention -101ms…please, where does this number come from?…it's likely correct if it's some standard. I came up with -110ms based solely on my own trials/errors…but after so many tests, trying to SEE that small of a difference, say between -100ms and -110ms, and verifying that it does in fact match the original AVI is nearly impossible. Again, I'm curious how -101ms was determined, or how standard it is.
I never could get BeSweet to work…and I hated its difficult functionality and GUI.
Though you say you see nothing special about AC3, I think it bears repeating that if you compare MPG-2 to AC3, you'll likely hear a slight hiss on MPG-2 (maybe only noticeable through headphones). I defended MPG-2 for a while but changed my mind recently after a back-to-back sound test. -
MP2 = tooLame (latest versions are great and fast)
MP3 = lame
Freq Converter (48>44 or 44>48 ) = SSRC
GOTO menu: Options | Environmental Settings | Audio Engine tab
Make sure that the 3 sections are using the above. Then make sure that you have the latest versions of each.
Many of the programs out there use these including BeSweet, etc.Thank You & Have a great Day! :)
reman
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 04:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
