Results 1 to 12 of 12
  1. When you convert a fa big file
    from avi to svcd and it take 8 hours to do it
    What would make it go faster
    Add CPU speed or add Mb of RAM ?
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    CPU speed is more important. More RAM will only let you multi-task better.
  3. It's all in the MHz/GHz buddy. Get a faster cpu.
  4. If I upgrade from a 1ghz to a 2ghz would i see a big speed difference ?
    Nice avatar Reptile
  5. More RAM could help a lot, but only if you don't have enough RAM to start out with. How much RAM do you have now.
    Assuming you aren't memory bound, doubling your CPU speed could halve your encoding time, but it depends on the CPUs you are moving from and to. Going from a 1 GHz Pentium3 to a 2 GHz Celeron isn't going to be as big a jump as, say, moving from a 1 GHz Duron to a 2 GHz athlon.
  6. It is from a pentium to a AMD Athlon XP
    I have 384 Mb of ram
  7. Doubling the CPU frequency (for a given CPU) will double the speed of conversion and cutting the time by 50%. If it takes several hours to convert a movie things like bus speed or HD speed don’t matter.
  8. Yeah this is what i saw ...
    It take me now around 3-4 hours instead of 6-8 hours for the same kind of file
  9. Originally Posted by bambam
    When I upgraded my CPU, my computer flew
    When I added RAM, my computer said "Shazam!!"
    When I dumped my first wife, I got back my life!!!
    Words to live by.
    A kiss on the hand might be quite continental, but tactical nukes are a boy's best friend
    Dec 2002
    My Swamp
    1G processor to 2G processor brilliant as long as your motherboard will take it . For that size jump you may need a new MB which will probably mean a different RAM as well ie DDR instead of SDRAM
  11. 1 - 2 and you will fly - if your mb will have it.
    If it's wet, drink it
    My DVD Collection
  12. I also change the motherboard but i kept the same memory
    No I can't do that !
    I rather have my girl friend than my computer
