Hi...
Do anyone know if you can make a code on a svcd?? So that if you want to play it in a dvd player you have to write an code before the film starts??
Simply create a menu sequence for this. Say you want a 3 digit password. Make three menu's, menu 1 links to menu 2 and menu 2 links to menu 3. Finally menu 3 links to the movie or to the main menu or whatever. The command to trigger each link is a number key of your choice. The only way to progress through each menu is to hit the appropriate key. You could make all other keys return you to the main menu so that they couldn't just guess.
Ultimately there is no practical way to protect a VCD or SVCD's content. This code method can easily be bypassed simply by turning PBC off, thus allowing you to navigate all tracks independantly.
Just get the last free version of VCDEasy and learn how to use it to create menus. If you like it go ahead and pay to get the full version, though the free versions should be more than adequate for what you need to do.
Question - how to make ffmpeg use mjpeg codecs when it encounters 4CC code
By bf4648 in forum Video ConversionReplies: 0Last Post: 12th Oct 2011, 16:53 -
how to improve my code to make better video quality?
By George2 in forum Newbie / General discussionsReplies: 6Last Post: 10th May 2009, 08:29 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 13:16 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10
