Since one thread got distracted without a simple answer I would like to pose the following questions... for those who may own a non-widescreen TV and who care to add some knowledge:
1) Does your DVD player have incremental zoom below 2x allowing a compromise of a slightly bigger picture with some side cropping for widescreen DVDs?
- toshiba SD-1600 (bought mine early 2002, no longer for sale): does allow for several levels of zoom below 2x.
- My early model xbox has 2x but no increment below 2x
-Panasonic S25S and S35, S75 (current?): all reported to have incremental zoom from 1X-2X in .01 increments
-panasonic rv32 (current): has 1.3x
-Toshiba 4700 (also no longer sold): Several increments under 2x
-Samsungs with "ez-view": something like 1.8x, which is better than 2x but I prefer 1.2x to 1.5x range
2) Does the zoom icon dissappear or are you stuck with it.
-Panasonic SD- 16002: The icon disappears after a few seconds.
-Early Xbox: The icon disappears
[note perhaps this should be considered as a noted function in the already excellent dvdrhelp dvd players compatability/functions list]
I agree and my earlier post could have been better titled (Like yours) This is my experience on 5 DVD players in the past 2 1/2 weeks:
Apex AD-2600 (Sticky zoom - I believe was 2X & 4X, Also cannot recall if had negative zoom, but I think it did, but otherwise played EVERYTHING)
JVC N55SL (No sticky - 1.8 zoom, 2x, maybe 4 also. Had negative zoom as well)
Philips 727 (Same as Apex listed above)
Toshiba 3260? (No sticky - Incrimental zooms - cannot recall different levels)
JVC DV-N312S (No sticky - 1.5, 2X, 4X)
There is also a Malata player Fulci posted and the zoom feature is totally custom, thats a player I want !!!!!
The last JVC is the one I am keeping - plays UDF format DVD,SVCD, VCD, MPEG-4, MP3, and whatever else. Weird thing is it wouldn't play various AVI and MPEG files on a CD however I burned all the files onto a DVD w/ Roxio 6 and played perfectly !!!! Strange..... All backups w/ DVD Shrink/Nero also played flawlessly. So as long as it is burned to their specs (I guess UDF?), it will play fine !!!
Not to beat a dead horse, but the (sticky zoom) is a major flaw by manufacturers !!!Even a fool can be wise, all he has to do is keep his mouth shut
Video techniques - shaking zoom in and zoom out effect?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 12:08 -
Question how to change icon of software icon
By jimdagys in forum ComputerReplies: 3Last Post: 10th Oct 2009, 05:47 -
Lower volume with Zoom Player
By genegold in forum AudioReplies: 2Last Post: 5th Aug 2009, 01:48 -
Zoom Player fast play button?
By BaloksPuppet in forum Software PlayingReplies: 4Last Post: 15th May 2008, 11:40 -
using zoom player to change aspect ratio
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 15th Oct 2007, 08:56
