I was wondering if there is any program that can take automatic screen captures from a DVD, while playing, every X frame?
Thanks in advance,
Nick
Depending on how long you want to capture, I would write an AviSynth script that would open the VOBs, select the SelectEvery() function, using the criterion of which frams I wanted, and use either Virtual Dub or TMPGEnc Plus to save to either AVI or MPEG respectively.
Hello.
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
Automatic - Programmed Capture into DV of analog source via Firewire Device
By lasith in forum Capturing and VCRReplies: 5Last Post: 12th Feb 2010, 04:03 -
DVD screen capture resolutions???
By cabala420 in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2008, 11:28 -
Automatic DVD Chapter Point Insertion
By cw4u in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2007, 00:43 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 11:48
