Results 1 to 10 of 10
    Feb 2004
    West Wales
    The picture I get on my TV with my new Pioneer 464 from my burnt discs of photos are no way as good as the photos are on my PC. Is there an obvious reason for this? Thank you
  2. Yes. The resolution from a computer monitor is vastly superior to a television. Stand close to your television and check out the lines. Not too long or it will make you sterile; or is that mast_____ing? Anyway, then stand the same distance from your monitor.
    LRD
  3. Member ebenton's Avatar
    Jul 2003
    The WINDY state (Florida)
    Buy a plasma or LCD TV.
    Feb 2004
    West Wales
    Thanks both, So thats it then. Cant afford either of those. I only have a Wharfedale 28" from Tesco so guess that does not help. Cant I use my Free view Digi box. Another stupid question I guess !!!!
    Dec 2002
    My Swamp
    Sorry william37 but you kinda answered your own question there.
    Feb 2004
    Montreal, CANADA
    I just PM to you a solution
  7. These are two different resolution types. If you want to get monitor quality, simply said, go buy a monster size monitor as you TV and you will get that kind of quality...
  8. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    So you are saying that a large computer monitor is going to give the same resoloution as a TV? You must be joking.
  9. @ richdvd
    Please read it more carefully !!! Monitor has a much higher resolution, why would it be the other way round. YOU ARE a so call A+ guy ??? What a joke ???
  10. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    Silly me, i should have known exactly what you meant by this well constructed statement.
    Thanks for letting me know
